MW piston for JD A
Steve II
01-06-2002 13:21:46
I have MW piston for JD A, one is A282 and other is AP134, what I have is one good of each and want to know if both can be run in same block? both are .45, I have been look around alot still dont find many of those, only damaged ones. where could I find more of those piston and rings. help be great. thanks. my tractor SN is JD A #540063 1944
Ron
01-07-2002 06:33:24
 Re: MW piston for JD A in reply to Steve II, 01-06-2002 13:21:46
If you do decide to use the pistons--IF they are alike..... . Be SURE to weigh them....they MUST be the SAME weight, or you will have some bad vibration..... I would have them weigh within 1 gram.... You might get by, if they are within 1/4 ounce...but will not be smooth, like a perfectly balanced set... You can lighten the heavyest one, if you are careful not to weaken it...!!!! Ron.
Steve II
01-07-2002 07:44:47
 Re: Re: MW piston for JD A in reply to Ron, 01-07-2002 06:33:24
Yeah that is what I plan to find out, will take it to a engine shop where they repair all kind engines from trucks to Hot Rods. they have showed me around their shop very likey and enjoy looking and learn alot. they use blue light on engines before doing work to be sure there nothing wrong.
right now I am waiting for piston to come in. and they too work on old tractors.
hope I have eveing work out.
John
01-06-2002 17:43:30
yeah, it should work
steveII
01-06-2002 17:51:08
 Re: Re: MW piston for JD A in reply to John, 01-06-2002 17:43:30
How do you know? been working on those before?
Steve II
01-06-2002 17:21:21
Yeah, Guess how long I have been looking, I had been looking long before the computers comes out on line.!! just found some so I am checking every where.
danny
01-06-2002 17:16:45
Well good luck cause I have been looking for a couple months and havent found anything yet. good luck
JEFF NOLAN
01-07-2002 17:34:16
 Re: Re: MW piston for JD A in reply to danny, 01-06-2002 17:16:45
HAVE A GOOD SET OF .045 PISTONS FOR AN "A" WITH RINGS, ANYONE INTERESTED?
