Crank?
Mike B
01-07-2002 09:19:30
I have two cranks with the same stroke. But one has 21/4" journals the other has 2" journals. Will there be a big difference in power if i would run the lighter one or the heavyer? Also have two different flywheels one 9" one 10" will this also make much of a difference? Thanks for any Info.
JDGnut
01-07-2002 10:09:10
 Re: Crank? in reply to Mike B, 01-07-2002 09:19:30
I don't think there will be much difference in the cranks weight.. but check the stroke of the cranks.. are they the same??? No Idea what brand tractor U have... JDGnut
Mike B
01-07-2002 13:25:29
 Re: Re: Crank? in reply to JDGnut, 01-07-2002 10:09:10
It's a oliver77 the stroke is the same one is out of a 77 the other out of a super 77. Thanks Mike
JDGnut
01-10-2002 07:24:45
 Re: Re: Re: Crank? in reply to Mike B, 01-07-2002 13:25:29
Just an Idea.. U could have the Super 77 off set gound to fit your 77 rods.. this would only push the piston up about 1/8 more.. and give you about 1/4in more stroke.. Not going to add much CID, but it will add some compression. Just need to check your pistons and see if they can stand the extra travel.. Just an Idea.. the price on grinding the crank should not be very expensive.. Good Luck
JDGnut
Mike B
01-12-2002 11:00:06
 Re: Re: Re: Re: Crank? in reply to JDGnut, 01-10-2002 07:24:45
If you offset ground it a 1/4" wouldn't it have a 1/2" more stroke? Wouldn't the piston go 1/4" higher and a 1/4" lower?
