Compression= Hp
Farmall Puller
10-16-2004 18:06:45
I have a farmall H If it has 150 p.s.i ove compression what should the HP be??
AC
10-16-2004 18:28:00
 Re: Compression= Hp in reply to Farmall Puller, 10-16-2004 18:06:45
Depends....that"s an awful open question.
How is anyone suppossed to answer that correctly when you didn"t give us any specs? Give us some more info.....
Farmall Puller
10-16-2004 18:33:48
 Re: Compression= Hp in reply to AC, 10-16-2004 18:28:00
It has a 3 7\16 bore with high compresion piston the head compleatly redone with new vaules it has a eletronic egntion and some other mods
ChadS
10-17-2004 07:30:03
 Re: Compression= Hp in reply to Farmall Puller, 10-16-2004 18:33:48
About 40. pretty good for a small cube engine. What are you looking for as far as parts? Might be able to help,, ChadS
Donny s
10-17-2004 18:28:35
 Re: Compression= Hp in reply to ChadS, 10-17-2004 07:30:03
chad wat do u have as far as performance parts for an H i wanna go bigger next year as in a stroker
ChadS
10-18-2004 07:43:39
 Re: Compression= Hp in reply to Donny s, 10-17-2004 18:28:35
Governor springs, limited slip/posi differentials, 3-9/16 and 3-5/8bore pistons for up to 5-1/4 stroker.(H-350) Higher compression stock bore piston, and sleeve kits. Carb rebuilding, dyno tuning, copper head gaskets, recurve springs for the distributor. email me if you have questions. Thats is about all I offer at the moment. ChadS
Mississippi Moonshiner
10-27-2004 18:51:50
 Re: Compression= Hp in reply to ChadS, 10-18-2004 07:43:39
Chad, do you have any performance parts for a Super "M"? I'm new to the sport of pulling and could use some advice. We pull in both a farm stock class and a farm stock plus class down here in south Mississippi. Thanks.....
