MM U JUGS
new puller
01-10-2002 09:01:28
whats the biggest piston i can put in my stock mm u without using M5 jugs. I am using my 6 in. crank
Glenn
01-11-2002 03:47:35
 Re: MM U JUGS in reply to new puller, 01-10-2002 09:01:28
The stock bore on a U is 4 1/4", you can go to 4 3/8+60 in the stock jugs. The 5.5 and up is also rite, but you have to open them up then weld sleeves in. Or I have some new casting that are made to put press in sleeves in. Glenn
mm
01-10-2002 10:25:06
5.5" is common,5.75 is possible and 6 in is expensive
art
01-10-2002 15:09:34
 Re: Re: MM U JUGS in reply to mm, 01-10-2002 10:25:06
4.81 boring out the U jugs. larger than that requires boring them out all together and putting in a new liner or going to the 800 jugs. 4.81 X 6 or 6 and 1/8 is a very cost effective way to get 400 plus cubes.
Desert Coyote
01-10-2002 22:36:57
 Re: Re: Re: MM U JUGS in reply to art, 01-10-2002 15:09:34
tell me more about this "800" year? wheel tractor? bolting on different jugs without machine work?
art
01-11-2002 16:49:50
 Re: Re: Re: Re: MM U JUGS in reply to Desert Coyote, 01-10-2002 22:36:57
MM built 810 cubic inch engines, most were power units, pumps, marine etc a few were in limited run G1000's specifically built to help the MM SS pullers. To make a long story short the jugs and heads that go with them are terrific so much so that even though they were manufactured during the right yearsand are a bolt on swap, most organizations do not allow them to be used. They are very good if you can run em. There are a couple U's around here with them and they are tough. Art
Adam
01-11-2002 17:39:18
 Re: Re: Re: Re: Re: MM U JUGS in reply to art, 01-11-2002 16:49:50
Ever thought about Cummings Sleeves grind out the block to the size then bore almost 500 cubes
art
01-12-2002 09:48:28
 Re: Re: Re: Re: Re: Re: MM U JUGS in reply to Adam , 01-11-2002 17:39:18
They work good but there is more expense in putting the sleeves in and altering the crank to line up with the big pistons. aRt
