Chad here is part of what you ask
Buckmaster
10-21-2004 17:28:03
The meatering screw on the carb i can back it out and get some black smoke but it dont run rough or try to quit or any thing i know its about 5 turns out rite now maby my drill wasnt big enough? it will idle way down to a put ..... ..... ..... .put ..... ..... ..... .puti got a pull sat so ill know more then the only dyno i have here at home is sone trees after i done all the stuff i told you about i hooked it to a tree well i uprooted the first one and switched the hell out of my back the next one i hooked to i had all the weights on7000 lbs on i pulled it in 2nd and let out when itpulled down i opened her up i was on a little bit of a down hill with the front wheels it started digen and i pulled it wide open the front wheels were of the ground it dug till the wheely bars bottomed out im a mechanic i know how to buld a race car and all that but tractors is new to me to me it sound pritty good to be in 2nd and pull the front wheels in clay i didnt think it was to bad on the gouvener you ask about it has 2 weights on it. thanks for all the help and ill find out the timing and compression and let you know this tractor was rebult i was told the 2nd owner said the 1st owner put a big kit in it i dont know
ChadS
10-22-2004 07:28:40
 Re: Chad here is part of what you ask in reply to Buckmaster, 10-21-2004 17:28:03
Sounds strong. I think your jet's are pretty close in size, If the engine works hard at the pull, try to check the plug color ASAP, pull it off to the side and pull out the spark plug. If is brown, to a dark brown in color, you are getting fuel to it, Compression test, and timing check. Sounds close on the balance, as long as when you idled it down and when you gave it the gas, it came back up you should be close. But spinning and no forward movement when pulling on the stump, loose dirt gets looser, kinda like that sweet spot in the track that 20 tractors take the same path, and it gets soft 12 ft from the leader marker. Balance with weight placement location could be the factor to get thru those spots.... I like to see the front end heavy enough to stay on the ground at a constant speed, if I give it some throttle, the front will raise about 2-3 inches, the tractor speeds up, and then comes back down, at the end of the pull, front should be up no higher than 10 inches on a decent track. Good thing about the Super M is the engine components when they changed the cam specs, head design, carb venturi, and a few other things in design. These engines made alot of torque, so they had much more lugging power over a M. So if it is very strong, think of how to put it to the ground. Good luck, hope this helped. ChadS
