Any Luck With Firestone 45 degree ??
bob
01-11-2002 07:46:06
I have a set of Firestone 45 degree 15:5-38 tires and i cant use cut tires has anybody had any luck using these tires in antique tractor pulling??? Let me know if they are good or bad. thanks
burns
01-12-2002 07:37:52
 Re: Any Luck With Firestone 45 degree ?? in reply to bob, 01-11-2002 07:46:06
Previously had a set on our 48 JD A before we switched to the 23deg Firestones. We found that 45deg tires worked best in the wet, muddy tracks. The bars would push the muck aside better. They would take a top ten finishing tractor and make it a top 5 finisher when it was wet, muddy. Matter of fact, we have an extra set of 14.9x38 45deg tires to me mounted on our Farmall 400 when we know it is going to be wet, muddy instead of the 15.5x38 Firestone 23deg bars.
Dale G
01-12-2002 12:10:12
 Re: Re: Any Luck With Firestone 45 degree ?? in reply to burns, 01-12-2002 07:37:52
I agree on a wet or soft track the 45's probably do work better but most of the time the track is hard and dry.
BJ
01-11-2002 18:35:18
In our area around here (NE IND.) a few guy's have 14.9-38's 45degree firestone on M's & MTA's and they are awfully hard to beat in thr 5500-7500 classes wouldn't mind trying a set on my G myself but they are pretty scarce and anybody that has a decent set isn't to inclined to part with them.
BJ
01-11-2002 18:35:08
Dale G
01-11-2002 12:31:26
Most of the tough tractors in our area are on 23 degree Firestones.
23 degree
01-11-2002 15:39:59
 Re: Re: Any Luck With Firestone 45 degree ?? in reply to Dale G, 01-11-2002 12:31:26
Yes, a 25% treaded Firestone Field and Road would be my choice.
45 tire
01-11-2002 23:09:36
 Re: Re: Re: Any Luck With Firestone 45 degree ?? in reply to 23 degree, 01-11-2002 15:39:59
I watched a pair of Gs pull against each other one with 23 14.9 and 45 14.9. they were both weighted the same with equivalant options. Both tractors spun out, but the 45 tires had the edge that won.
TGW
01-12-2002 06:00:26
 Re: Re: Re: Re: Any Luck With Firestone 45 degree ?? in reply to 45 tire, 01-11-2002 23:09:36
Most of the time the 45's will loose out. The only tire that I have seen that will get the same traction or better than the 23's are the Wards Riversides, now they can take power away.
