Ford/Funk............stock?
DEEREHART
01-11-2002 21:30:38
Just wondering what you guys thought about a Ford 8N with a Funk 6cyl conversion pulling in a stock farm tractor class? I pull the Green stuff but I found this and thought it might be fun.
Jason
01-12-2002 13:52:04
 Re: Ford/Funk............stock? in reply to DEEREHART, 01-11-2002 21:30:38
I have seen the V-8's pull before. All they do is break traction. The Fords arn't ballanced as good as some of the other tractors out there. Just not enoff weight on the back. I guess you could add weight,but then that would put you in a higher class and the extra horse power wouldn't be mutch help.
Troy
01-12-2002 05:56:23
They also came as a v-8 flathead kit. And no they are not stock unless you think a v-8 flathead with stock 90hp is stock for the tractor. But it would be fun!!! But pick it up if you can get it reasonable.
