G head burns
B crocker
01-12-2002 17:34:14
I pull with my 49 g in the vitage class.we are allowed max 55hp ,my tractor dynos 43 on our dyno.i bored 120 over and put aluminum clevite pulling pistons in last year.every thing else is completly stock.i would like to give her a few more hp iam thinking of milling the head and maybe putting a intake from gerrys on.could i get some feedback on this idea please? also my head is a chambered and iam wondering how much i can take off without running into problems?
lynn
01-13-2002 15:53:15
 Re: g head burns in reply to B crocker, 01-12-2002 17:34:14
a g with .125 pistons and a cold manifold should make around 52 hp with stock parts..much as i like jerrys parts i don't think the big manifold will help much with less than 500 cubic inches..if you can change the manifold without taking the head off try that on a dyno..make a carb adjustment and play with the timing to see what you get..if you can't get over 50 hp with a big nut carb i would pressure check the cylinders to make sure the valves are not leaking..lynn
Size
01-14-2002 07:06:03
 Re: Re: g head burns in reply to lynn, 01-13-2002 15:53:15
What is the size of the larger intake diameter?
Burns
lynn
01-14-2002 16:22:27
 Re: Re: Re: g head burns in reply to Size, 01-14-2002 07:06:03
we put one on a tractor in november..can measure it this weekend but guessing it is around 2 1/2 inches..lynn
burns
01-13-2002 06:48:35
Todd is correct about removing .250. I would caution you that someone might have already removed some material prior. The cyclone head has the economizer eyebrow around the intake valves. If the head hasn't been cut, .250 will get you real close to that eyebrow but I wouldn't go any further. Any sharp edges in the combustion chamber should be rounded off to prevent hot spots. With your stock cam, your valves will have plenty of room between the pistons. I run a flat head, high lift cam, 1/16" head gasket and have .010 decked from the block and I have plenty of clearance.
As far as the manifolds, I would check with Detwiler to determine the diameter of the intake port. Jerry's smaller manifold has a 2" port. Whoever does your machine work to open the intake runner, be sure that they open the runner all the way down to the cavity behind the intake valves? Blending the opening with a die grinder part way down is not what you want. Not everyone is equipped to run a 2" end mill down a 6" long passage way.
ralph
01-13-2002 04:14:17
I have a jd A and what i did was put bigger valves in and shined up the ports and manifold, helped gain about 15 hsp
DP
01-12-2002 21:02:44
You would help the ole girl out a lot by just putting a gas manifold on her. The high compression pistons are not being used to there max if you are running with the all fuel manifold. Also wouldn't hurt to shine the ports on the head and manifold. Good luck!
Todd
01-12-2002 20:23:26
You can take off .250 off the head. The Jerry's manifold intake port will be larger the the intake in your head. I don't really see any advantage without matching ports in the head. Detwiler tractor has new cold LP style manifolds for G's (detwilertractor.com). You might also try roller rockers from murphy's motor service, I don't know how much that will help on a basically stock engine. All these are ideas that are not relatively expensive, or require a lot of modification.
