G flat power block
Dennis W Seller
01-13-2002 11:41:00
What HP can be expected from a styled G with flat head & power block? Is it much more than flat head & aluminum pistons?
Mike S
01-15-2002 21:16:30
 Re: G flat power block in reply to Dennis W Sellers, 01-13-2002 11:41:00
A friend has that setup he pulled 61 HP on the dyno.
John
01-16-2002 20:17:05
 Re: Re: G flat power block in reply to Mike S, 01-15-2002 21:16:30
My dad has a regular G with .090 aluminum in it and his runs 68hp. His cousin has 65hp and is the same as dads. I think a regular block is the way to go.
John
Farmall SM
01-15-2002 15:15:02
You don`t need a power block to pull first gear, unless you want to start to be known as second gear Sellers!
John
01-13-2002 15:29:14
no, it won't be much more, maybe 5 or 7 hp, at the most. Plus the regular block and that is alot cheaper. There is debate between a flat head and that swirl head. I don't have a favorite.
John
