Attn. Firefarm and other hot rod tractor owners.
crewter
11-14-2004 19:53:38
I am very interested in building a smallblock hot rod tractor in the 5300 and 5500 classes. I come from more of a automotive background so tractors are kind of greek to me, but I am learning. Would anyone mind sharing what they have built? What would be a good model and make of tractor? Do I run the tractor trans or a auto trans or both? Any other web sites worth looking at? Any help would be greatly appreciated.
Brad
firefarm
11-17-2004 13:04:44
 Re: Attn. Firefarm and other hot rod tractor owner in reply to crewter, 11-14-2004 19:53:38
You've got mail...
KDobias
11-16-2004 17:44:34
The Northeast Nebraska Pullers Association Inc. has a V-8 Modified class 5000-5500 pound
www.nnpai.com and look for rules
V-8 Farmall
11-15-2004 13:48:37
Put in a search word SATPA. these ate the V-8 antique rules we use in West Texas.
Sandyland Puller
11-17-2004 09:45:48
 Re: Attn. Firefarm and other hot rod tractor owner in reply to V-8 Farmall, 11-15-2004 13:48:37
Here is the link to the Sandyland Website just click on the rules link for the V-8 rules.
crewter
11-15-2004 19:05:46
My rules are COATPA. They are very similar. Would you mind sharing your setup? I am tractor shopping now. Any ideas.
Brad
V-8 Farmall
11-17-2004 06:30:21
 Re: Attn. Firefarm and other hot rod tractor owner in reply to crewter, 11-15-2004 19:05:46
Small Block Chevy bolted directly to farmall motor plate. made input shaft to accept chevy clutch stuff. fabricated Throwout bearing arm off of existing farmall lever. This system works well but had to go to a brass lined clutch, stack chevy will not hold.Other than that the swap is ptetty straight foward.
KDobias
11-18-2004 15:41:54
 Re: Attn. Firefarm and other hot rod tractor owner in reply to V-8 Farmall, 11-17-2004 06:30:21
I built a Super M with a 400 chevy bolted to the M motor plate. I used the 11" cluch disk off an early M put it under the stock chevy pressure plate. Use the M in-put shaft had to turn the piolet shaft down to fit the chevy piolet bushing also had to build 2" spacers between the in-put shaft and tranny. The clutch is holding for me
