ChadS, 460 question
GeorgiaRed
11-17-2004 15:06:02
I have a 460 gas, what head will fit and give more compression, thanks
ChadS
11-18-2004 11:14:32
 Re: ChadS, 460 question in reply to GeorgiaRed, 11-17-2004 15:06:02
There was one basic design for the cyl heads on the tractor IH 6cyl. Most of the compression chambers are all the same on the tractors. The IH trucks that used the same block as the tractors, used a high compression head that is just like bolting on an LP head on a letter series Farmall. One problem,,, the truck heads are only compatible with flat top pistons, the fire crater pistons used inthe 460, will hit on a truck head. You can get truck engine kits, and put them in the tractors,, then use the truck head. Hope this helps,, ChadS
