For JD A piston
steve II JD4000
01-16-2002 18:50:16
is there any different on the weight of JD A piston? light weight piston or heavy weight piston?
Ron
01-17-2002 22:07:26
 Re: for JD A piston in reply to steve II JD4000, 01-16-2002 18:50:16
Some were cast Iron ( real Heavy ), and some were Aluminum ( Lighter )... Always weigh each piston to be sure you have a Balanced set.... if you don't and one is heavier than the other, the engine Will have a Shake... All JD 2 cylinder piston--Rod assemblies were weighed to check for weight, before assembly at the factory... You can lighten the heavyest one, to match the other... Ron.
steveII JD4000
01-18-2002 11:22:18
 Re: Re: for JD A piston in reply to Ron, 01-17-2002 22:07:26
what ones would make the engine work harder or gives it more power. I have are MW pistons one is A282 and other is AP134 have not find two that same number. still looking or will both work if wighet same.
Ron
01-18-2002 18:06:40
 Re: Re: Re: for JD A piston in reply to steveII JD4000, 01-18-2002 11:22:18
I suggest youask Mr. Clooney.!!
I personally would use the Aluminum pistons... I feel that since they are lighter, they pose less load on the Rods, and are not as likely to break..... !! If aluminum pistons are annodized on the combustion end, they will absorb less heat--the main advantage of a cast iron piston.... OR, you can have the piston tops Ceramic coated, to lessen the heat absorpion even more....! I have NO idea if your 2 pistons are designed to give the same compression....!!! Ron.
