Cast iron vs. Aluminum piston
Curious
01-17-2002 08:54:17
If the pistons were the same size and length, would there be an advantage to use one or the other type? I've heard some say that a cast iron piston would help with torque more than an aluminum piston, but most everbody with a modified tractor uses aftermarket or specialty aluminum pistons. This would apply to any brand of tractor. Your thoughts please
LDL
01-18-2002 20:06:13
 Re: Cast iron vs. Aluminum piston in reply to Curious, 01-17-2002 08:54:17
Having extra heavy pistons, flywheels or cranks to create torque is purely a myth. You only need things to be heavy enough for structural strength and to smooth out an engine. Anything more is just dead weight.
01-18-2002 21:03:45
 Re: Re: Cast iron vs. Aluminum piston in reply to LDL, 01-18-2002 20:06:13
not completely!!
G Taylor
01-17-2002 14:24:15
Lighter pistons reduce the stress on the rods/crank/mains/block if they are re-balanced.If not a harmonic(s) due to vibration can add up & break parts. Particularly vital if the engine is reved past it's "redline". Centrifical force & linear inertia increases four times when the speed is doubled. Nine times more force when the speed is tripled. Some claim "more" torque due to increased piston inertia but there is also more weight to accelerate as well.
I would go Alum.
01-17-2002 17:35:58
 Re: Re: Cast iron vs. Aluminum piston in reply to G Taylor , 01-17-2002 14:24:15
