Dead man throttle on a Farmall....
AC
12-01-2004 14:20:59
Can I run a throttle cable to the governer on an H or M up from the bottom, to pull the gov (down) for full throttle, and letting a spring at the top (or just the gov action) provide for tension as I let off? Those Governers can only go down so far and open up so far, right?...I am just curious...Am I wrong?....AC
FARMALL
12-01-2004 14:41:17
 Re: Dead man throttle on a Farmall.... in reply to AC, 12-01-2004 14:20:59
Thats the way I have my 'M'. Works just fine but you will need a return spring. FARMALL
AC
12-02-2004 14:21:28
 Re: Dead man throttle on a Farmall.... in reply to FARMALL, 12-01-2004 14:41:17
Did you make your own, or is there a setup out there that already works with little or no modification...I was looking at Greg Lemmons Saturday , and I liked the way it was built, but I like the one on Jared's tractor, if that is the one I am thinking of....thanks, AC
