Need Impco 200T carb
LW
01-18-2002 19:36:47
Need to find 200T carb, thanks LW
Mr LP
01-21-2002 16:05:45
 Re: Need Impco 200T carb in reply to LW, 01-18-2002 19:36:47
The 200T is the same carburetor as the 200D. The "T" is for turbo. That is why the CFM numbers are so high. The only differents is in the throttle shaft seals.
LW
01-21-2002 19:30:24
 Re: Re: Need Impco 200T carb in reply to Mr LP, 01-21-2002 16:05:45
No, the T is for triple because it has 3 diaphrams it is not the same as the 200d with another one it is an altogether bigger carb it has a 3.687 throttle bore the 200d has a 2.687, go to the impco web site , all there listings say turbo compatable, LW
Mr LP
01-21-2002 20:51:34
 Re: Re: Re: Need Impco 200T carb in reply to LW, 01-21-2002 19:30:24
Well I guess you know it all. Why don't you buy one. I'm sure Impco would be glad to take your money. The 200D has different throttle plates. All the way up to 3".
LW
01-22-2002 07:19:47
 Re: Re: Re: Re: Need Impco 200T carb in reply to Mr LP, 01-21-2002 20:51:34
NO I don't no it all but I don't call myself MR.LP either, don't get mad because you didn't know, and I probably will buy one from impco, they are very proud of it at 1,500$ that is why I posted the message.LW
