Family Tradition,, Power steering Idea,,,
ChadS
12-11-2004 04:35:04
Got an idea to run past you,,, Seen Were looking for an idea on a rack n pinion. IH made a sweet set up on a Hydrostatic steering system, that uses hoses,, instead of Steering linkages. You find them on the 706-1456,,, or the IH late 403-915 combines. I used this set up for my 460, and instead of a rack, it has a cylinder for rack. I used a Ford power steering pump, and it has plenty of pressure to operate it, and the pump can be stepped up in the pressure line to set the desired feel in the steering wheel. Ididnt step up the pump, but sure is easy to steer! I have a scematic of how it is set up Id be happy to show u what it looks like! ChadS
family tradition
12-11-2004 13:27:48
 Re: Family Tradition,, Power steering Idea,,, in reply to ChadS, 12-11-2004 04:35:04
wouldn't that be quite a bit heavier than a regular rack and pinion? trying to shed some pounds!
baystatebinder
12-22-2004 04:39:04
 Re: Family Tradition,, Power steering Idea,,, in reply to family tradition, 12-11-2004 13:27:48
What kind of tractor and where do you pull Family Tradition. There is a pro stock called family tradition that pulls in New Brunswick Canada.
ChadS
12-11-2004 13:37:50
Enire system for mine was around 37# including the pump. ChadS
PULLER
12-11-2004 13:45:13
 Re: Family Tradition,, Power steering Idea,,, in reply to ChadS, 12-11-2004 13:37:50
I used a hydralstic steering off a 4400 combine, worked good ,I have been using it for 6 years, put the steering motor in the steering shaft, pump on motor and cylinder below,
