460 560 farmall
460Jason
12-29-2004 18:32:02
What is the lowest weight class you guys have seen these tractors in. The 460 and the 560.
What weight class do they pull best in?
How light can they be taken down to easily, by removing parts and going pressed wheels, etc.?
460Jason
01-01-2005 20:22:28
 Re: 460 560 farmall in reply to 460Jason, 12-29-2004 18:32:02
Ok I guess I"m on my own except for 2 lonely responders on the 460- 560 question. NO other pullers have any input good or bad on this topic??? I know someone has to have some input.
Lenny
03-06-2005 08:10:42
 Re: 460 560 farmall in reply to 460Jason, 01-01-2005 20:22:28
Yes I have seen 460s in the 4000 lb. class real easy I used to pull a 560 and easily would get into the 5000 lb with wide front asnd all weight brackets ansd safety equip. I started with a 301 block and stroked it to a 340 360 is also easy with a 4 inch bore. I have heard of 389 cubes but takes al ot of massageing in the crankcse, cam and oilpump area.
A.P.
01-02-2005 03:13:39
I am not sure what else you are looking for. The other two gentleman answered your weight question. As far as what weight classes you pull it depends on your local rules, classes offered, how much you have to spend, what has already been done to the tractor and how much weight you want to throw around. A 460 usually make a very nice 4500-6500 pound tractor, assuming slow mph classes and a good TA and engine. I would recommend finding a 301 engine as a starting point if you plan on modifying the engine.
Good Luck!
AC
12-29-2004 20:09:41
You can get them into 3750, but you better have $$$$$$$$. Forget pressed steel....one word, aluminum. EVERYTHING you can make, fiberglass for everthing else. It's a job, but it can be done.
460
12-29-2004 20:58:01
 Re: 460 560 farmall in reply to AC, 12-29-2004 20:09:41
with just steel you can get to 4200 thats what we are at and i see one on the pulloff page in the 4 sale ads that one is real cheep with extra parts.
