600+ Oliver 88 motor
c shaffer
01-05-2005 03:56:32
I'll be starting my motor next week. If anyone is looking for the biggest cube 88 motor I can do two at the same time. Best to email me for details.
88 puller
01-05-2005 16:17:02
 Re: 600+ Oliver 88 motor in reply to c shaffer, 01-05-2005 03:56:32
Sorry, want the biggest, try closer to 700
D.H.One
01-06-2005 05:11:54
 Re: 600+ Oliver 88 motor in reply to 88 puller, 01-05-2005 16:17:02
He meant HP not cubes!
88 Puller
01-06-2005 15:37:15
 Re: 600+ Oliver 88 motor in reply to D.H.One, 01-06-2005 05:11:54
No, he meant cubes cousin!
stroker88
01-05-2005 18:29:25
i think both of you guys are either full of crap or flunked 5th grade math. there just isn"t that much room in a stock 88 block. unless you can use deck plates.
c shaffer
01-06-2005 05:20:30
 Re: 600+ Oliver 88 motor in reply to stroker88, 01-05-2005 18:29:25
hey stroker I m going to 617 cubes. 6.125 stroke and 4.625 bore. Offset bore, furnaced brazed darten sleeves,bilt rods,Ross pistons, copper head gasket. I can do this.You'll see it on NATPA pulls next year. I hope you can come to one a see.
stroker88
01-06-2005 18:06:57
 Re: 600+ Oliver 88 motor in reply to c shaffer, 01-06-2005 05:20:30
yeah, it"s possibe, but far from sensible. they are just to hard to feed, and can"t make power if they don"t get air.
88 puller
01-06-2005 10:00:39
how long will it live, how many times can you hook it without cool down time. if i'm in a pulloff i want to go.
c shaffer
01-07-2005 14:46:05
 Re: 600+ Oliver 88 motor in reply to 88 puller, 01-06-2005 10:00:39
we have already had a 597 cube motor out there for two years. Unforunetly I can't tell which one it is without permission. This is the same just bigger bore. cool down time i'm not workied about, pull-offs should be no existant with this baby. All I need is the way to the winners circle lol.
aggrivator
01-07-2005 16:25:03
 Re: 600+ Oliver 88 motor in reply to c shaffer, 01-07-2005 14:46:05
We have something you might like to pull against! It's large and yellow,not a school bus.I have to say that 66 was impressive at Junius good luck with the 617 I may want to update Locomotion sometime,maybe drop me a E mail we will chat,we'll set up a play date for tractors. Rich
