Building Farmall H Engine
Bill
01-26-2002 15:22:00
OK I Am Building up Farmall H its Bored out to 350 Spec and Have Super H Head also Super H Manifold I Plan on Going with 350 Carb and would like to Know if Anyone has any Thoughts on Cam? Maybe stock 350 cam would be best if its Differs from H cam? I also have Electronic Ing for Tractor and Hve Head Milled .060 and plan on Running Hy Grade Fuel at least 100Octane. Any Thoughts? Thanks
hot stocker
01-27-2002 19:32:16
 Re: Building Farmall H Engine in reply to Bill, 01-26-2002 15:22:00
sounds like your gonna have a strong running H. i had an H motor built for me and it sounds like you've done about the same that i had done. Did you take a cut on the valves? I had a 30 deg. cut on mine. the sooner those valves open the better. I used C-12 racing fuel, but that was just my preference. as for the cam, i like the 350. i thought it gave me more low end torque and a lil more hp. good luck at the pulls.
