ChadS
01-12-2005 10:11:24
Re: Copper Head Gasket Trouble in reply to Kenny Chinsey, 01-10-2005 16:49:38
You may have had a fingerprint in the coppercoat sealer on the gasket, Ive sprayed all surfaces, block deck, both sides of the gasket, and the head deck, let it dry and become real tacky, (bout 1-1/2hr) then assemble. Dont skimp on the cleaning, it has to be dry and clean before the sealer is sprayed on, old sealers around the head studs, or overspray on the head studs can scrape down the studs and lodge in between the sealing surfaces. Main thing is to have the block deck, and the head surface perfectly flat and matched. If that is done you can seal it with no o rings. if it has not been done,, youll fight it. the 450 head gasket is larger than the M head gaskets in the bore of the fire ring, It can seal a 4-3/8 bore, but will overhang the cyl, not much but only catches half the fire ring for a good seal. After about 50 times of self learning this procedure, I fianlly got em to seal the first time. Take the extra time and have a set of flange rings made to fill up the sleeve flange left over, then you can use the 450 head gasket to a better advantage VS on one that dont. Fingerprints, Uneven block surface, head surface, will fail a copper head gasket everytime! Overtorque on the studs dont help much, just overstresses the block deck, and pushes the warped area more and more,, ChadS
