ChadS
01-14-2005 14:17:31
Re: ? for CHADS Hcam in reply to Chum, 01-13-2005 15:44:38
I have a 53 Super H, that pulls div 1 type classes, this tractor, started it all for me in antiuqe tractor pulling, on an NCIATPA pulling track, it is the one to beat in the 3500-4500 farm stock classes. It has firecrater, 3-1/2 bore, it has a 8043DD Early super H cyl head, same casting as the 300-350 heads, but the old H head number, milled .200. no port work. It has a 4 weight governor from the factory, with one of my springs, the Super H-350 camshaft, and the big carb and manifold factory stock on a Super H. Now, This ol Super H is no stranger to the dyno, 15 years of testing and tuning on it, It started out as a 39 hp tractor. Its 45 now, and still more to make more hp. Add a lp head, it would be over 50 hp, at less than 169 cubes. But, we are not working with a lp head. First, how many hours are on your engine? if its less than 100, and not used much, well the rings still may not be seated in, if it has a bit of blowby, then run it on the dyno a bit longer. May still not be broke in. Run a compression test. pull all the plugs out, open the throttle all the way, and crank the engine. Check all 4, and see if there is a difference in the readings. if so, you may need to retorque the head, reset the valve lash, any adjustments to be made to get the peak cyl pressure for that cyl. While you have the plugs out, look at the color, are they black? lite brown? If you can get the main jet to flood the engine when backed out, your fuel could be giving up, if its like 87 or what have ya,, you may need to step up to a better grade gasoline, it depends on your compression test results. at 120psi, you are 35-38 hp. at 150 psi, you are 38-40. At 175, it can vary a bit. Seen this before, cause the cam and head comes into play at 175psi, that is really the starting point for compression, for the IH to make power at the smaller cubic inches. Even though only 25 psi more, it makes a huge difference in how these engines breathe. thats where the late head and cam come into play. The torque wakes up big time, and the improvements can be more clearly noticed. These are very peppy engines when souped up a bit. It takes compression. Have you milled the head? what have you done exactly?? Let me know, or email me, would be happy to help. ChadS
