Flow bench results?
redhead
01-27-2002 06:44:19
Has anyone played with a IH450 gas head and manifold on a flowbench? I'm curious how many cfm it would flow with stock valves and mild cleanup work on the ports and runners. Thanks.
AGCOPULLER
01-29-2002 14:22:26
 Re: Flow bench results? in reply to redhead, 01-27-2002 06:44:19
I recently flowed some stock WD45 A-C heads and was quite suprised how well the old flathead really flows. 134cfm intake and 128cfm exhaust @ 28" of H2o. I don't have any numbers on the IH head but I assume it would be Quite similar to the stock head since the combustion chamber volume is its major difference.
Brad
01-29-2002 18:29:02
 Re: Re: Flow bench results? in reply to AGCOPULLER, 01-29-2002 14:22:26
I found this site the other day when I was looking around. They might know the information that you are looking for. They have some pictures of a modified farmall carb on a flowbench and what looks like a M-450 manifold on the flowbench. Looks they also sponsor an antique tractor.
BL
Brad
01-29-2002 18:39:45
 Re: Re: Re: Flow bench results? in reply to Brad, 01-29-2002 18:29:02
I'll try again
