A carb
john deere pull
01-13-2005 18:35:44
I am in need of a bigger carb for my 36 A will the dltx 51 or the 71 be better what would be the best
Earl S.
01-13-2005 19:53:23
 Re: A carb in reply to john deere puller, 01-13-2005 18:35:44
JD Puller, Your carb will depend on your cu.in. and comp. ratio . A good start I would recommend the 71.Then if you need I can make a 51 or 71 bigger.The 51 is a all fuel carb and the 71 is a gasoline carb. I think the mid range is better on the 71 due to fact of the economizer jetting Email for detail. Earl in Illinois
