Changing the power steering on a JD 4010?
ed welsh
01-13-2005 22:08:59
What is involved in changing the power steering to a cylinder style on a 4010. I want to put a lighter front on to reduce weight.I would like to save the orig steering column if I can.
Chip
01-15-2005 22:50:54
 Re: Changing the power steering on a JD 4010? in reply to ed welsh, 01-13-2005 22:08:59
Don't know why you can't use the two lines that run to the stock front, just run those lines to each end of a steering cylinder (like a combine) If the steering cylinder is too big in diameter you'll just have to turn the steering wheel around more turns. Make the axle between the spindles heavy enough I've seen them buckle when it comes down. Where you located??
