Fruitland Pull
PULLER
01-19-2005 04:53:56
Are we going to see another interesting 5500 open class again this year.I like the excitement
PULLER
01-19-2005 10:09:47
 Re: Fruitland Pull in reply to PULLER, 01-19-2005 04:53:56
The track condition were good depending on your tractor. the 900 case that won the 5500 open thought the track was great. I truly believe some of the other competers got a little to light in front and could not control their tractor
O.K.
01-19-2005 20:05:55
 Re: Fruitland Pull in reply to PULLER, 01-19-2005 10:09:47
WOW-he won a pull! what a jerk!
strickler
01-19-2005 08:02:41
the only excitement I saw was the 6000 class. The 5500 had potential but track ruined it. When people are dropping 2-3 gears just to try to move sled cause it was so slick, that should tell you something!
49 MM U
01-19-2005 15:16:21
 Re: Fruitland Pull in reply to strickler, 01-19-2005 08:02:41
Seems like they lengthened the chain for that class to keep them from pulling so far but I cant" remember... I just remember that hot-rod massey with flames all over it hopping up and down and spinning alot. Seems like he came back in the next one with more weight on the back and did better though.
PULLER
01-19-2005 16:09:06
 Re: Fruitland Pull in reply to 49 MM U , 01-19-2005 15:16:21
YES. Your right ,But I believe the weight should have been added on the front. I have seen the massey pull before and it seems like the driver is always out of control.
Ken B
01-19-2005 05:39:06
When is the Fruitland pull I need to Mark it down . Good pull Ken B
Ken B
01-19-2005 05:37:56
When is the Fruteland pull I need to Mark it down . Good pull Ken B
puller
01-20-2005 03:08:57
 Re: Fruitland Pull in reply to Ken B, 01-19-2005 05:37:56
sorry you cant afford pulling maz. then you know
