Head gasket thickness
jd b puller
01-22-2005 20:54:34
Getting my B ready to put back together. In calculating the compression ratio, what do I use for the compressed thickness of the head gasket?
Thanks, Ray
torquenut
01-25-2005 04:34:24
 Re: Head gasket thickness in reply to jd b puller, 01-22-2005 20:54:34
Could you just simply measure the old gasket you removed? This is of course if you plan to use that style. I would est it being around .065. You can get gaskets made in different thicknesses so keep that in mind, composite or copper. Composite from Lubbuck would be .032, .062 and I believe two thicker sizes, copper ???
