BEST TRACTOR 3500-4500
LOOKING
01-24-2005 16:00:28
What tractor is best to pull 3500 and 4500 classes. Have to run 1st gear only and can't have a tire bigger than 13.6-38 because that is the biggest tire size allowed in 3500 but want to run both classes competitively.
Deere Hunter
01-27-2005 08:48:15
 Re: BEST TRACTOR 3500-4500 in reply to LOOKING, 01-24-2005 16:00:28
Give me an e mail if you"re interested in a WC.
Kurt-AllisPuller
01-25-2005 14:52:33
It's tough to beat an Allis in the 3500# class. I run 2 WD's and one with 14.9 - 38's and Its always top three usually only beat by other Allis Chalmers.
CASEPOWER
01-25-2005 12:10:15
Ford's in this area. I prefer a old Case C or CC. 3500# is no problem.
A.P.
01-25-2005 09:46:06
An Oliver 66 or 77 would both work well in the 3500 - 4500 pound classes. Some places will not allow the 77 in the 3500 pound class. The 66 will need a set of 3 3/4" pistons and sleeves for the 4500 pound class on tight tracks.
Mopower
01-25-2005 07:27:14
Look at a Minneapolis Moline 335. The interchangeable parts on an MM can make this tractor a monster in these classes and very easy to build. U302 3.75 blocks and a 5" crank from larger models bolts right on making 165 cubes to 220 easily. Bored? You can get 236. This is no stroking. A stock 220 power unit ran 66 horsepower. Good luck. Look at maybe a MM R too. Less power but still can be modified easily.
FB
01-28-2005 21:31:00
 Re: BEST TRACTOR 3500-4500 in reply to Mopower, 01-25-2005 07:27:14
nice gears in those torquey lil beasts too
aik
01-25-2005 05:28:46
my brother-in-law wants to sell his oliver 70 its ready to pull in stock class. it has bigger pistons and head an intake wook. new paint all side sheilds there 13.6-38 tires weight brackets ready to go 2300 email for phone number thanks
jd b puller
01-24-2005 19:25:24
Fact of the matter is, with a little luck, skill and some work, you can make darn near anything work in 3500. Since you are limited to 1st gear, the AC would have a slight disadvantage becasue they came with overgrown bicycle tires and you can put 13.6-38"s on them (makes them go a lot faster).
Personally, a 1st gear rule is one of the silliest rules I have ever seen. It just allows the people who "bend" the rules to do things like swap out gears so thier hopped up tractor can go faster. If you are gonna pull these rules and want a B, stay away from the ones with the 6 speed tranny, as it goes a little faster than the race at the retirement home.
JD B
AC WC
Farmall H
Small Oliver
Kip[UT]
01-24-2005 17:59:04
We clean up @3500 &4000 w/ a totally stock 37 Allis-Chalmers WC. 4500 is a little tough though. With a WD-45 Crank & some other tweaks the WC can be very competitive at these weights.
JDGKid
01-24-2005 16:21:40
Maybe a H Farmall or an Allis of some kind
