? for chad .s
BUCKMASTER
01-31-2005 18:56:11
chad i do a good bit of engine work im a mechanic worked on just about any thing and every thing ive bought all kinds of preformance parts for chevys to harleys to hondas the most noticeable preformance ive ever put on was a thing called a atomizer screen on my harley it went be hind the carb it looks like a dish sink drane stoper ive never heard of any one trying on on a tractor do you think it will work on a up draft on my harley i had to turn the idle way down that told me the fuel was mixing better what do you think
hobby77
01-31-2005 21:47:09
 Re: ? for chad .s in reply to BUCKMASTER, 01-31-2005 18:56:11
did that on my 77 oliver .it helped the miss it had at high rpm`s and helped on low end as well.
ChadS
01-31-2005 19:20:38
Ever see the intake manifold gaskets, that have screens in them? Very fine screens that they say chop up the air/fuel mixture more, breaking it down farther due to more fuel being able to mix with the air. Turbulence in the ports can be a good thing, as long as it is not a restriction. Id say it helps torque, as well as a bit of hp in certain rpms that could stand a bit more mixture to fine tune it, and create a more stable hp reading. Dont try to restrict the air flow, just churn it up some,, more than what the tractor was not designed to do. More dense, and mixed air fuel ratio, the better power you will make. In some cases where you described on your Harley, it increased the vacuum level through the intake, requiring less adjustment to create the same conditions that cause a noticible change, at less turns of the idle, or the main jet. Does help fine tune, just have to know what to interpret, the changes that happens inside the chamber, plug colors, jet settings, etc etc. ChadS
Buzzman72
02-01-2005 06:36:04
 Re: ? for chad .s in reply to ChadS, 01-31-2005 19:20:38
Did I just see a reference to a more dense mixture?...anybody ever try ice where the oil's s'posed to go in the air cleaner? [LOL]...OK then, anyone ever ADMIT to doin' that?
Chip
02-01-2005 22:15:10
 Re: ? for chad .s in reply to Buzzman72, 02-01-2005 06:36:04
I (hide) my nitrous bottle in the oil bath air filter and run an 1/8 inch brake line inside the pipe to the carb.
CLARENCE BARENIE
02-01-2005 18:42:10
BUZZMAN
DID IT MAKE A NOTUCABLE DIFFERENCE !
SOUBDS LIKE A GREAT IDEA !
Ohio H
02-01-2005 12:49:15
Oh yea' Thats what a "cool can" (any perf. catalog) does'. Aluminum fuel line spirals down through a can of ice. Dry ice,much colder works great.
clarence barenie
01-31-2005 19:59:55
cone !
