966 engine question
560puller
02-01-2005 16:11:46
I have a 966 414 engine that is used on the farm and also to pull out of the field farm class.The fuel is turned up all the way and the torque riser set up,I have been told that setting up the timing would help,I think it is set at 18 now.Any ideas on getting more power whether through a different air filter set up or any other ideas would be appreciated>Thanks Ky pullers
pcy1066
02-02-2005 05:01:41
 Re: 966 engine question in reply to 560puller, 02-01-2005 16:11:46
when pulling take the filter out, set the timeing to 30 degtrrs, if you have a turbo on it 36 degree, a small inline pump a- or m-n-w 42 degree and a p pump about 48
smoker
02-02-2005 18:49:57
 Re: 966 engine question in reply to pcy1066, 02-02-2005 05:01:41
i think those numbers are alittle off,a P should be around 42 and that is if you want to spin at 6000 plus.
stock pump set to 24.
