Heating a Power BLock to clean
b power block
02-02-2005 18:17:11
What would happen if you dropped your Power block off at the shop, and they heated it to 550 and bead blasted it? Would it destroy the Orings? (the heating was part of the cleaning process so they can magnaflux it to check for leaks)
Earl S.
02-02-2005 19:59:46
 Re: Heating a Power BLock to clean in reply to b power block, 02-02-2005 18:17:11
"B" Power Block. Pressure test your block(7lb.) to see if it ruined the sleeve seals.Power block clean up in spray washer with non caustic cleaner then pressure tested for leaks is the correct way to clean & check a power block.You really need to ask the shop if he knows what a Tractor Supply Power Block for a Deere is?????Magna flux would find a crack but wouldn't find a leaky sleeve seal.Email might be able to help you. Earl In Illinois
