H front end weight
45-H
02-05-2005 15:05:08
Does anyone know the weight of a complete H Farmall tricycle front end with the wheels , tires and steering shaft? Thanks
ChadS
02-06-2005 08:47:56
 Re: H front end weight in reply to 45-H, 02-05-2005 15:05:08
Just a rough estimate, the upper bolster is around 145, the lower bolster with cast centers is around 95-110. Steering shafts are around 18. Ive replaced my steering shafts with aluminum, and at one time cut up an upper bolster under the radiator to lighten it up, got it to around 75 lbs, and still pretty strong. Ive replaced them, our rules dont allow it, I only run them for when I need to get a bit more under 3500. Build a lite weight wide front if you are going to change anything, if the rules will allow it. ChadS
