Pulling a Minneapolis Moline 5 Star
Tom
02-01-2002 16:54:53
I'm interested in hearing about experiences in pulling a MM 5 Star.
In our area (Oregon), most tractor pulling is done with more or less stock tractors. Hitches can be modified for height and hitch point, the RPM can be boosted a little but for the most part the tractors are pretty much stock. That is, we don't go down the road of M5 blocks and G cranks on 283 engines.
So is it possible to get the 5 Star in the 6000 lb. class without going to aluminum rims or other high zoot lightweight parts?
How competitive is the 5 Star against, M, 460 & 560 Farmalls, John Deere 60's and 70's, Allis D17's and the like in both the 6000 lb. (if possible) and 7000 lb. classes?
Is 2nd gear low range considered a good gear to pull in or is low/low best?
Your thoughts and experiences would be most appreciated.
Tom
rick moman
02-14-2005 09:58:47
 Re: Pulling a Minneapolis Moline 5 Star in reply to Tom, 02-01-2002 16:54:53
I HAVE BEAN PULLING A 57 5STAR LP FOR A FEW YEARS. IT HAS A336 ENGINE,MOSTLY STOCK. MAXED OUT AT 74HP REVED UP,65 AT STOCK RPM. I RAN THE STOCK CAST RIM WITH 15.5 38 IN THE 6500-7000 LBS CLASSES. ISPUN OUT ALL THE TIME. I SWITCHED TO STAMPED STEEL RIMS WITH 18.4 34. THEY WORK A LOT BETTER.IRUN HIGH FIRST AND TQ. IT IF THE CLASS LETS ME.SECOND GEAR IS TOO MUCH.WITH ALL THE HYDROS 3 POINT 150 LBS. OF WEIGHT BRACKETS, AND A 2X SIZED DRIVER IT WEIGHT 6200 SO WITH A LITTLE STRIPPING 6000 SHOULD BE EASY,STAMPED RIMS HELP ALOT I DO GOOD WITH THE LIGHTY MODIFED SUPER M,5000 FORDS JD G,70,720.BUTWITH AL OF THE BIG CUBED HIGH RPM TRACTORS OUT THERE I SOON LEARN WHEN I'M OUT CLASSED I'VE HAD THE BEST LUCK IN THE CLASSIC FARM 7000-8600 LBS. CLASSES.MY UNCLE RUNS A G CRANKED LP UB. IT IS ALWAYS IN THE RUNNING AROUND HERE. SURE WOULD BE NICE TO HAVE HIS HP IN MY TRACTOR.HOUSE PAYMENTS FIRST TRACTOR SECOND. STILL HAVING ALOT OF FUN WITH MY 5STAR,SURE GETS THE LOOKS,ALOT OF OLD FARMERS LIKE SEEING ME PULLING MY MINNIE I ALSO GET ALOT OF QUESTIONS ABOUT THE LP. GOOD LUCK WITH OUR 5STAR.
