Farmall Hitch Setup
KL
02-02-2002 16:47:43
Anyone out there have any tips, tricks or even a picture of a good hitch setup for Farmall 400 or similar? I've got a design in mind but would like to hear from others too. Has there been good sucess by attaching to the axles ( like the hoop drawbar is done ) or is it better to attact to the rear end casing? Thanks for the suggestions.
JIM FUNK
02-04-2002 16:21:59
 Re: Farmall Hitch Setup in reply to KL, 02-02-2002 16:47:43
HI I HAVE A M AND A 560 PULLER ALSO HAVE A JOHN DEER BUT WE WONT SAY MUCH ABOUT THEM [STICKTORED]
ANY WAY IF YOU ARE RUNNING WITH A FAST HITCH U CAN GET THE SET UP FOR THREE POINT AND BUILD A DECENT HITCH BUT I WOULD NOT RECCOMEND THIS BECAUES FAST HITCH WAYS ALOT AND U MAY BEABLE TO GET IN DIFFRENT CLASS WITHOUGHT ON MY 560 I TOOK IT OFF GPT AN ORRIGANAL DRAW BAR C CLAMP THAT IS UNDERNETH AND TOOK MY PTO OUT MADE A STEAL SLAB WHITH A ADJUSTER AND A REST AND IT DOES FINE AND LAST BUT NOT LEAST U CAN GET AN ORRIGANALL DRAW BAR AND TURN IT AROUND DO NOT KNOW RULES WERE U PULL IF QUESTIONS RITE BACK THANKS JIMMY
Dan
02-02-2002 21:32:11
I use a shortened stock drawbar on my 400 and an adjustable hitching point works well but you will need to check the rules with whomever you pull.
