44 Standard
Kevin
02-16-2005 18:12:09
I have a Massey Harris 44 gas standard and want to pull it yet show it off as the rare tractor it is around here. So of coarse i want it to be stock for show. But Should i built a bolt on/bolt off hitch that is 18" high and 18" away from the axel and not put on wheelie bars or should i put wheelie bars on? Or am i just best and safest pulling off of the stock drawbars if im going to do a quik bolt on hitch?
Reason why im thinking of no wheelie bars is becuase its a standard, has 14.9x30 tires, shorter frame and a pretty heavy looking front. I dont like taking chances though so what do you think?
mH49
02-17-2005 19:00:32
 Re: 44 Standard in reply to Kevin, 02-16-2005 18:12:09
I would put a set on if it were me. A lot of places require them now anyway. With a little creative engineering, I would bet you could fabricate a set that would be strong enough to support the weight of the tractor but could still be installed and removed in very little time.
Slo
02-17-2005 18:45:22
No one ever got hurt by having wheelie bars heavy enough to work, placed in the right spot. I pulled a row crop 44 in 4500 and up, and it was light in the front at just over stock hp using a hitch 18" up and 18" back in 4500.
Kevin
02-17-2005 16:30:08
No one has any thoughts or opinions on this one?
Augie
02-17-2005 17:38:20
 Re: 44 Standard in reply to Kevin, 02-17-2005 16:30:08
I've got a feeling that after you pull it a few times you'll be wishing that you'd bought a Moline...
Kevin
02-17-2005 17:44:36
 Re: 44 Standard in reply to Augie, 02-17-2005 17:38:20
Dont say that, i could of had a moline UTU(i think) for $500 but it needed 1 new rims and 4 new tires.
No, main reason why i bought this tractor is for show and to have alittle fun at pulls. When i get serious about pulling ill get something that i wont care about ripping apart to get more power...like a john deere.
But my question was do you really think i should put wheelie bars on it? Ill probly run the 5,550lb class with no weights.
Augie
02-18-2005 10:49:34
 Re: 44 Standard in reply to Kevin, 02-17-2005 17:44:36
Was just razzin ya. To answer your question - yes, put wheelie bars on the tractor. Better safe than sorry...
cockshutt446
02-18-2005 06:46:08
I think you should have them i have a 44 just like that its just more safe. You know the old saying have a ten dollar head wear a ten dollar helmet. whats your life worth?
