GOVERNOR ? H same as Super M
BUCKMASTER
02-17-2005 15:51:40
can you interchange one another or do you have to get the governor specific to your model?
halfbreedm
02-17-2005 21:22:41
 Re: GOVERNOR ? H same as Super M in reply to BUCKMASTER, 02-17-2005 15:51:40
the govenors are the same they will fit either tractor
superih
02-18-2005 08:20:16
 Re: GOVERNOR ? H same as Super M in reply to halfbreedm, 02-17-2005 21:22:41
The governor mechanism is the same but the linkage from the governor to the carb. throttle rod is different lengths. If you are thinking about unbolting the entire governor from one tractor to the other you will have to change the neck ontop of the governor housing and the linkage. Hope this helps.
BUCKMASTER
02-17-2005 16:13:14
 Is MW power governor any better/different than a in reply to BUCKMASTER, 02-17-2005 15:51:40
Thanks
clarence barenie
02-18-2005 15:14:42
 Re: Is MW power governor any better/different tha in reply to BUCKMASTER, 02-17-2005 16:13:14
govenors are the same housing
fly weights are a different weight also !
m@w govenor design is completely different.
4 weights instead of (2) also much better bearinf in the nose !
