Fuel Tanks
That Black G
02-20-2005 01:00:09
Im looking to move my fuel tank from the big tank under the hood, to a smaller tank maybe like 5 Gallons. I have seen quite a few Gs in the hook with the relocated tank out front on the weight bracket... do you need a fuel pump in this case?
Also, I want to instal a technical system to keep an eye on Engine Temp, RPMs,... oil pressure. What system, or guage system do you guys run, and how hard is it to instal.
Thanks
70 puller
02-20-2005 10:24:47
 Re: Fuel Tanks in reply to That Black G, 02-20-2005 01:00:09
You have to run a fuel pump because the carb is higher than the tank.
jugs
02-20-2005 14:55:15
 Re: Fuel Tanks in reply to 70 puller , 02-20-2005 10:24:47
What kind of fuel pump...model? does this affect the float in the carb?
That Black G
02-20-2005 12:32:38
That was edxactly what I was thinking.
the real CONFEDERATE
02-20-2005 16:17:06
 Re: Fuel Tanks in reply to That Black G, 02-20-2005 12:32:38
get a universal electric fuel pump from NAPA it pumps between 6 & 7 lbs of pressure and will not hurt your float valve you have to pump over 10lbs of pressure to do that.
That Black G
02-20-2005 18:52:59
 Re: Fuel Tanks in reply to the real CONFEDERATE, 02-20-2005 16:17:06
So it pumps that constant all the time? So does the tractor take the same amount of fuel all the time... idle vs WOT (Going down the track)... or is there a link between the throttle and the pump.
ToddF
02-21-2005 09:01:32
 Re: Fuel Tanks in reply to That Black G, 02-20-2005 18:52:59
The float and needle still stop fuel flow, the pumps are likely diaphram pumps that can generate 6-7 lbs of fuel pressure; the float will be able to stop fuel flow into the bowl at that level.
That Black G
02-21-2005 19:59:27
 Re: Fuel Tanks in reply to ToddF, 02-21-2005 09:01:32
Thank for the info... ant idea where to get one of these fuel tanks at?
