JD hauler
02-22-2005 18:18:56
Re: Big cube A's in reply to Would like to know, 02-21-2005 08:30:02
If I could have afforded a heisler head I would have done that, I think you can get the same out of a good worked cyclone head, I would have liked to experiment with cams more, I liked my redone #71 carb, liked the msd ignition, it started great cold or hot, that always impressed me and didnt even have a choke in it, it had roller rockers, it was a dependable beast, usually pulled locally here in Pa, but the Big dollar G's came on the scene and it really wasnt competitive anymore and while it was still running good I sold it, it pulled div 3 and sometimes 4 here locally, I never dynoed it because I dont have one, and nobody around here really had one then, that I had rights to be on, now I have a friend that has one and could have used it anytime, my guess is solid 75 or so, cant honestly tell for sure. If rules here would allowed it, maybe a spacer plate behind the block, could have run longer rods, would have liked to try somthing other than slant top pistons, maybe those aircraft pistons, here jerrys heads are too much for an A, good for G's, overall if you build the 530 , it will be around for a while, put rod bearings in every season to freshen that up, cheap insurance for 25.00 from deere, I would also liked to have about 170 to 185 psi compression, mine was lower than that, that is what my 2 cents is, mike
