660D FOR PULLING?
706.
02-23-2005 10:28:23
DOSE ANYBODY NOW IF A 660D WOULD BE GOOD FOR PULLING THANKS
Donnie T
02-23-2005 21:10:12
 Re: 660D FOR PULLING? in reply to 706., 02-23-2005 10:28:23
We built a 560 Standard to pull with. We put 18*4*34 tires on like a 660. It pulled real good in 1st gear torque in high, in the 8500lb. Keep the front end down. We pulled off of the stock "U" shaped hitch. Beat alot of the big Deeres. It seemed to get a real good bite. E-mail me for some more info if you want.
720Deere
02-23-2005 19:10:59
I don't know about the 660, but I pull with a guy that has a 650. They should be about the same. That 650 is tough to beat in the 10500 class.
Farmall Daddy
02-25-2005 09:02:42
 Re: 660D FOR PULLING? in reply to 720Deere, 02-23-2005 19:10:59
A 650 only a 4 cylinder diesel when the is available as a 6 cylinder gas, diesel, or LP version. Plus, the 650's didn't have the torque amplifier on them. I believe that a 660 gas, or diesel would make a great puller in the heavy weights, 8500 and up. I have heard that they have pretty good size bull gears in the rear end to hold the pressure. Good Luck!!
