Hard to start
A puller
02-25-2005 15:47:42
I have a John Deere A with electronic ignition and MSD. It very hard to start when warm. Is it in the timing if so what sould it be set at and how many RPMS while setting it?
Drew
02-25-2005 17:37:39
 Re: Hard to start in reply to A puller, 02-25-2005 15:47:42
Have you put big petcocks in it? If so, try starting it with them not quite all the way open. They sometimes are a pain to start w/ big petcock all the way open.
A Puller
02-25-2005 18:34:30
 Re: Hard to start in reply to Drew, 02-25-2005 17:37:39
It has a Power Block with the big petcocks in the front of the block though a stud. It starts real easily when cold. Would being hot or cold make a difference with the size petcocks. Thanks for all information.
Drew
02-26-2005 09:14:55
 Re: Hard to start in reply to A Puller, 02-25-2005 18:34:30
Sounds like we have simular setups. The big petcocks can let out too much compression. I dont know if tempature would make that big of a difference. If you have a second person with you when you are starting it, get it rolling over and then have someone shut the petcocks. Just be careful that it doesn't kick back. Usually the MSD box makes it start MUCH easier.
