Alum weight brackets
730-LP
03-08-2005 18:35:35
I have some 1/2 X 4 kaiser 6061-T6511 alum can I heat and bend it at a 90 degree angle or will it have to be cut and weld.thanks
farmall2
03-09-2005 07:36:30
 Re: Alum weight brackets in reply to 730-LP, 03-08-2005 18:35:35
You will need to cut & weld the bracket. If you heat and bend tne aluminum you will take the temper out and will be weak.
Ken(MI)
03-11-2005 09:00:54
 Re: Alum weight brackets in reply to farmall2, 03-09-2005 07:36:30
If you weld it, you will also compromise the heat treatment, the only proper way to fabricate aluminum for maximum strength is to anneal and re-heat treat when fabrication is complete.
