A not running right
Falcon
03-09-2005 10:18:51
Trying to tune up an A. Just won't idle smooth. Changed plugs, wires, gas, carb, changed dist over to good mag, timing is dead on, comp. is 125 both cylinders, sprayed starting fluid around intake, nothing helps. Tappet clearance is correct. What am I missing... I am not new to this...What am I missing??? Thanks.
puller 2
03-11-2005 17:18:17
 Re: A not running right in reply to Falcon, 03-09-2005 10:18:51
I have to agree with Drew, if it smooths out under load don't worry about it . I have a 60 that has always idle on one cyl, but with a load on it , it runs perfect.
Drew
03-09-2005 10:43:54
Does it smooth out with a load? If it is just at an idle, it is normal to run on one cylinder. With the carb. butterfly closed, the left cylinder sucks in its intake charge and there isnt enough time for the runner to fill for the right side 180* later. As soon as a load is applied and the carb opens up, both cylinders get a more equal charge.
