Farmall H clutch
W.B
03-21-2005 20:16:34
I heard of guys putting heavier springs in their pressure plates. I"d like to put heavier springs in my H. What do i use? Thanks
ChadS
03-22-2005 04:01:14
 Re: Farmall H clutch in reply to W.B, 03-21-2005 20:16:34
Bout any clutch shop can, or has a heavier spring set. you could use washers to shim behind the spring, or, change the flywheel,clutch and pressure plate from one used in a 300-350-460 IH tractor. bigger diameter clutch, use a super H clutch disk when using this set up, it is the same diameter as the big clutch, and same as the H spline on the input shaft. Hope this helps,, ChadS
