Dekalb Div 4
Ohio M Puller
03-22-2005 10:16:27
My question is what Div 4 rules are they going to be running. Last years Dekalb at National Rules, Last summer was OSATPA"s 3 Plus Rules, & now they have something totally different. Just wondering what to plan on so I know what tires I could run.
Ohio M Puller
newagain4010
03-23-2005 09:42:48
 Re: Dekalb Div 4 in reply to Ohio M Puller, 03-22-2005 10:16:27
The way I read it, it's 5 mph with any cut tire (18.4x38 or smaller). My question is, if there's an rpm limit of 2500, why do I have to take my steel fan off?
MH49
03-23-2005 04:24:17
I personally hope they run the new rules. Pulling is more about the engineering than anything else and what better way to feed that need than to open it up but still leave a conservative speed limit on it? I can't wait to see a turbo Oliver 88 diesel run against a big cube M or a JD G or even dare I say a Kubota? I give kudos to the COATPA people for trying something new. I don't think that the newer tractors will dominate but the biggest issue that I see is that the WD45 Diesel will probably dominate the light class.
minnie ub
03-22-2005 17:09:57
i asked the same thing a week ago and didn't get a response.if i read it right now div 4 is any age tractor and turbos are legal,its not even a antique class any more. i hope at dekalb they run the 3+ rules or national 4.
Ohio M Puller
03-23-2005 04:32:23
 Re: Dekalb Div 4 in reply to minnie ub, 03-22-2005 17:09:57
I called good old Joe and sure enough he was NO help, he told me I had to talk to Tyre Lathem which he isn't even pulling with COATPA anymore. I should of know noone would give a straight awnser since it has to do with an antique class, compaired to if it was any of the others. So I quess they will have to call it the Mystery Div.
Ohio M Puller
minnie ub
03-23-2005 17:35:49
 Re: Dekalb Div 4 in reply to Ohio M Puller, 03-23-2005 04:32:23
lathem still pulls antiques doesn't he. i wonder if the rest of the div 4 tractors will pull against turbos or try to drop to div 3.
