Are these injectors big enough?
1256 puller
03-31-2005 18:23:39
I just got a 450 Roosamaster pump for our 1256 and a set of .093 lines. The pump puts out approx. 400 cc of fuel. I have a set of 4 hole .014 tips.Are these big enough to run with this pump?Also,the pump came with a hardened shaft.
LDW
04-03-2005 11:05:03
 Re: Are these injectors big enough? in reply to 1256 puller, 03-31-2005 18:23:39
Way to small!!! You'll lock your head and rotor up right away! If you want to run 4 hole injectors, need at least a .025 if your pump puts out 400 cc's. If you need to get new tips made, a 5 hole would actually be better, you can run a little smaller hole then, get just as much fuel flow, and get better atomization, makes a faster more efficient fire from the fuel. If you need anything I can get it for you, we're setting up a 1206 and a 1456 for some guys right now, both 450 pumps, big lines, injectors, and some other goodies, etc.
Rusted farmall
04-01-2005 06:47:00
When you say 400CC is that per injector, or for all of them in a given period of strokes? Is that done on a 1000 stroke count? Just thinking about my farmall down the road and getting ideas.
pulling
03-31-2005 19:58:50
I would say you should go to a bigger tip. .014 seem pretty small especially if your 450 is good for 400cc's. Not good to pump a lot of fuel through such a small hole. May cause pump problems. Just go to .025, more fuel the better.
856 puller
03-31-2005 19:43:24
we run a pump like that and we used .025 for a while now they are .035. .014 sound small to me
