Crankshaft Drilling
RCP
04-03-2005 17:55:06
Does anyone have any contacts who can drill an Oliver crank and convert it to pressure lube rod bearings?
stroker 88
04-04-2005 19:17:01
 Re: Crankshaft Drilling in reply to RCP, 04-03-2005 17:55:06
why? i've never had or seen any problems with rod bearlngs in the waukesha engines that squirt oil the rods, and we have put alot of compression and stroke in them.
stroker 88
04-04-2005 19:15:10
why? i've never had or seen any problems with rod bearlngs in the waukesha engines that squirt oil the rods, and we have put alot of cmpression and stroke in them.
CASEPOWER
04-03-2005 18:21:11
third party image
It's really not that hard. Any machine shop should be able to handle it. I drilled mine with the drill press you see here. A good vice and a 8 inch 3/16" bit was used. Use a full fluted bit to carry your shavings out. If you don't you will break a bit. The shell of the crank is harder than the inside. Use a die grinder to start a flat for the drill bit on the journal. The actual drilled hole was 6 inches on this Fordson crank.
