1206 injectors
ih460puller
04-05-2005 20:09:07
What are the biggest stock ih injectors & pump I could put in a 1206?
856 puller
04-06-2005 18:36:18
 Re: 1206 injectors in reply to ih460puller, 04-05-2005 20:09:07
you can put a 450 head in your pump. the 0degree housing might be better though. have stock tips lazered to .o25 make sure to get big lines.
Redman
04-06-2005 17:18:56
1456 will fit for sure,you could also check on the 4100 4WD they had a 429? ci same style block as a 361/407.
Think I Know
04-06-2005 22:47:52
 Re: 1206 injectors in reply to Redman, 04-06-2005 17:18:56
The 429(from 4100)4 roller pump will fit on a 1206.
Redman
04-07-2005 13:00:49
 Re: 1206 injectors in reply to Think I Know, 04-06-2005 22:47:52
i thought that was it,been awhile since i checked on that.
when i last checked they changed the rules so we could throw on a P.
856 puller
04-07-2005 15:19:09
 Re: 1206 injectors in reply to Redman, 04-07-2005 13:00:49
if you can run a p doit
Redman
04-08-2005 05:00:28
 Re: 1206 injectors in reply to 856 puller, 04-07-2005 15:19:09
did,then found that the 407 was at a disadvantage to the 466 deere and the 400 series IH,even after punching it to 440 ci and porting the head.
switched ot a 436 now and make better power and turn more Rs.
856puller
04-08-2005 14:59:10
 Re: 1206 injectors in reply to Redman, 04-08-2005 05:00:28
the 400 series is hard to beat. we only run the 407 because we have to. as far as pumps go the rosa works but the p is mutch more durable and can have all the fuel the 407 could hope to burn.
Redman
04-09-2005 06:36:42
 Re: 1206 injectors in reply to 856puller, 04-08-2005 14:59:10
i will agree with all of that,but i would also add that the 400 series is not as dependable as the old 407.
when i pulled the 407 i changed oil and that was it,not i get to do midnight overhauls.
in defence of the 436,it is being pushed hard to keep up with the 570 IHs and 585 deeres.
856 puller
04-09-2005 09:54:17
 Re: 1206 injectors in reply to Redman, 04-09-2005 06:36:42
at least you can make it keep up. i dont think any amount of work will make the 407 stand up to that kind of competion. we found performance parts and know how are hard to come by a lot of stuff is by guess and by golly
