4'' auto piston for a M
dave
02-10-2002 17:13:23
compression hieght 1and 1\2 . what to get?
ff316
02-12-2002 19:05:17
 Re: 4'' auto piston for a M in reply to dave , 02-10-2002 17:13:23
Go to your local auto parts store and ask them if you can browse through the piston catalog. All the SB Fords are 4" bore. Some piston catalogs may even have a size chart that is seperated into bore, pin height, etc... Be careful about some aftermarket pistons, make sure you get the right sized rings.
Mike in Mo
02-11-2002 15:42:38
Dave I measured a Ford 351W piston, it has a 1.74" compression ht and .910 wrist pin. Ford 351 Cleveland, 351 and 400 Modified, and Chevy 350 all have a 4.000 bore. Aftermarket suppliers have a wide range available, especially for the Chevy. Check with Jegs, Summit, PAW performance auto parts. Hope this gives you a place to start. Mike
DougS
02-10-2002 23:53:10
A piston from the old 427 GM truck block.
