ChadS/ Gov-Spring
AJB
04-11-2005 18:35:41
Chad, I have a '47 H with two wt. govenor. I had a neighbor say he put a 450 spring in his Super H is that as good as the spring you use? I recurved my dist. and now want to play with govenors. My nephews old M will open if it runs over big dirt clod, mine not that active. Thanks Andy
ChadS
04-12-2005 07:04:48
 Re: ChadS/ Gov-Spring in reply to AJB, 04-11-2005 18:35:41
If the spring he has is the stock big loop, stock stye, no,, they are not the same as what I have. You need to make the sring tension tighter,or stiffer. Your looking to increase governor responce time, from when you pull back the throttle, and the time it takes for the governor to respond and control the carburator. Usually, on a governor that still has a stock spring in them,, when the engine has a hard pull set on it, and begins to power stall the engine, the governor weights, overcome the spring tension quicker,, and shuts the carb down prematurely. Makes the engine stall out faster. Lazy throttle responce is from a stock spring, hard to get rpms and then it will stretch the stock spring. A good spring, and it will wake it up a bit,, when you speed the governor responce time up,, you better be ready to rebuild your carb, cause you are changing the engines running characteristics that what it was originally designed for. His super H, also has the updated cam, and cyl head so he mite have a bit more over a Stock H, (if that is what you got) If its competition your looking for, start reading the rules,, and see what you can use for parts. Cams, and heads from the SH-350 will wake up an old H. Hope this helps,, Chad
AJB
04-13-2005 04:26:38
 Re: ChadS/ Gov-Spring in reply to ChadS, 04-12-2005 07:04:48
Chad, I rebuilt and rejetted my carb and recurved dist. this winter. I followed the steps you had posted for another Farmall owner. I'm doing this in steps as I get time. I now want to replace gov. spring and reset carb with tractor on my cousins dyno. I farm full time and work this in as a hobby. How much are your springs and what is the time frame of getting one to Central Illinois? I tryed to bring your web site up but must have something entered wrong. Thanks Andy
ChadS
04-13-2005 07:14:46
 Re: ChadS/ Gov-Spring in reply to AJB, 04-13-2005 04:26:38
Click the link below for the site, Just make sure that when you dyno it, you are able to get above 540 pto rpms, 600-615 pto rpms should be plenty. Email is open, or call 574-893-7437 ask for Chad, or Earl. Thanks! Chad
