JD B puller
Andrew
02-13-2002 04:17:30
I am wondering how much power i could get out of a JD B(bored and stroked), and what prices would I be looking at?
Ron
02-15-2002 06:21:32
 Re: JD B puller in reply to Andrew, 02-13-2002 04:17:30
There is a JD "B" Power Block for sale--look down the page, here..!! That is probably your Best Bet.... Have new seats installed in the head, to get the valves up to their original height... Have the valves contour-shaped, to flow better
( no angles)...clean up the ports, and LOOSE the Muffler.....!!!! Have the piston tops annodized, or Ceramic Coated--they will not absorb as much heat--makes more power.... If you have a NEW, fresh BORE.., rub Dupont Teflon into the cylinder walls, and heat to 200* to set it into the metal...rings will last a LIFETIME..... Stroking is just too much to consider....the axles won't take all that much more than it already has..!!
Roy
02-15-2002 18:41:17
 Re: Re: JD B puller in reply to Ron, 02-15-2002 06:21:32
Had a unstyled B bored and stroked pulled 3500 and 4500 pound class
