Anybody cut tires to make them look roadworn?
SKIP
02-16-2002 21:30:43
any pointers or suggestions?seems to me this is what DIV2 has become and ineed a little help to compete also.
LDL
02-19-2002 17:42:57
 Re: anybody cut tires to make them look roadworn? in reply to SKIP, 02-16-2002 21:30:43
Can't beleive there are so many willing to help you cheat. That must mean that there are many more who do cheat but don't talk.
deadeye
02-19-2002 05:33:57
I have used the steel disc that you cut tires with to get the lug down to where you think you want it. Then smooth it up with a regular 7" grinding disc. Works best to do it in cold weather as rubber don't get as hot.
Kurt
02-18-2002 22:51:00
I cut my tires with a hand held planer. It took a long time but it got me 2 1st places before I got caught. Oh yah if you dont like that idea a buddy of mine chains the front of his tractor up and then spins his wheels backwards on pavement. Just dont; do it on to rough of pavement. Good luck!
Bob-Wyo
02-18-2002 20:35:09
Kris borrow or rent a hand held wood planner, it's fast, cleaner and really hard to tell it.
You can do back relief at the same time and if you are carefull can touch up the leading edge.
Had to sharpen the blade once, really works great.
Hope this will help,
Bob
Ps; make sure the tread is as clean as you can get it first.
john
02-18-2002 09:44:29
my family uses a knife to get the first bit of rubber off, then a grinder to finish them(bring LOTS of extra grindin wheels cause they load up)
John
farmall flogger
02-18-2002 08:44:02
You'll be all right till you start winning. Then look out, they'll be on you like flies on a watermelon. But then again it's like that with any edge I reckon. Good Luck!
JD G GUY
02-17-2002 17:38:39
just wonderig why do you want "roadworn" tires for pulling wouldnt you want more tread. im still somewhat new to old tractors and was just wondering
chris
02-17-2002 16:58:02
A friend of mine that used to pull always took his handheld 4 1/2 and 7 inch grinders and ground tire to what he liked, just thought I let you know chris
Sam
02-17-2002 14:02:34
I used a chainsaw one time . The other time I bought used tires from the farm tire dealer . Actually he gave them to me so he didn't have to pay at the dump .
G PULLER
02-17-2002 09:29:57
put them on backward, add weight,let the pressure down to were the tread sets flat on the road.enjoy the drive
Paul
02-17-2002 05:58:35
Just get your 15 yr old kid to run it up and down the road There road wore and LEGAL.
Jim
02-17-2002 08:30:54
 Re: Re: anybody cut tires to make them look roadworn? in reply to Paul, 02-17-2002 05:58:35
I have heard to tie the front to an anchor of some short and put it in reverse and let it spin on a hard surface
